02-23-2019, 09:49 AM
#2801
OK, finally mounted the panels to the roof, using VHB Tape and 3m 5200 sealant. The cables still need to be secured, and edges sealed a bit more. The second the panel hit the VHB Tape, it was stuck; if I was going to mount another set, I'd have another set of hands or keep the tape unwrapped at the sides, so as to keep the sides from sticking until the center was set and ready, as it moved real quick to being stuck. It's pretty good, yet I wanted to adjust them a bit more. I used a Blue Sea cable clam to pass-through the roof. Might add a simple wind deflector to keep air from shooting under the panels, as there's a little space under the center of the panels, though not sure what to use yet.
Originally Posted by Fool120
I've installed most of the solar system (Renogy 200watt flexible panels) minus the panels, and will install them when it stops raining for long enough on a weekend. The tricky part was running the conduit/wires behind the side panels from the old TV cabinet to the rear batteries. To do this, I had to remove the fridge to get a clearer shot behind everything. The 2 sensor wires (voltage and battery temp) were pretty short, so I had to make it a short run to the batteries. While there, I also ran a piece of conduit behind the upper cabinets to run the cables from the panels, down to the controller. I backed the van under an overhang on my house, which makes it easier to climb onto the roof; the pic shows where the panels will go, behind the vent.
Rob
'97 Ford E350 EB 7.3 PSD
Quigley, Sportsmobile
02-23-2019, 09:56 AM
#2802
Very tidy and clean.
02-24-2019, 03:57 PM
#2803
I got the power...
Out with the old...... In with the just as old.
2006 Ford E-350 6.0
03-02-2019, 06:50 PM
#2804
Finally resolved the hi-boost whistle and loss of power on my 6.0. Started around 8-10 months ago. I've blown turbo hoses before and it is obvious whoosh sound with extreme loss of power. This has been a whistle at higher rpm's and slight loss of power. Started looking around a couple weekends ago and saw quite a bit of oil residue around / under the first blue hose coming out of the turbo. A little research indicated it's a good sign of a hose with a tear in it. Bought hot side turbo end and CAC end boots and spent 2 hours swapping them out today. Was very happy to find a slit in the turbo end boot! All is good again. Power is back and whistle is gone.
Phil
- 2005 EB50 6.0PSD - SMB 4x4
03-03-2019, 10:27 AM
#2805
Reinstalled the galley box, used to be white & needed it to match our wood (maple & cedar) look we have going on in the van now, also did the back doors & one side barn door in cedar with a bottle opener added.
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
03-03-2019, 11:57 AM
#2806
That looks nice.
Rob
03-04-2019, 09:42 AM
#2807
got a 24" hightop form a junkyard last weekend!
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
03-04-2019, 02:58 PM
#2808
You know, in some circles, the whistle is a feature!
03-04-2019, 06:22 PM
#2809
Nice! Looks great on there.
03-06-2019, 09:24 PM
#2810
Rear spring install
A year ago, I installed new front coil springs, Fox shocks, and steering stabilizer, and this year decided to go for the rear leaf springs too. The original rear leaf springs were the 22yr old, and I'm assuming stock springs on 3" blocks. The old springs showed some damage and wear, so I decided not to just add a new leaf or two. The new springs, were from Agile Offroad, and were made to get the same 3" lift without the blocks, and take the van weight a little better. The springs seemed quite heavy, yet the install was still doable in the driveway. Most of the install was maneuvering the spring to the right spot, yet to get the last bolt, it took a bottle jack and C clamp, to get it to line up. I took it for a spin around town, yet still need to secure my Solar cables, on the roof, before heading out for a real trip. Hopefully I can take her out real soon.
Rob
