Old 04-20-2011, 10:32 AM   #1
Zeta's Avatar
What winches fit Aluminess Bumper?
Been looking at 12,500lb winches for my rig. They all seem to be 10+ inches tall and the bumper is only 9.75". What winches are SMBers using?
Thanks
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 04-20-2011, 12:24 PM   #2
Re: What winches fit Aluminess Bumper
I'm using Mile Marker in my bumper-12500#. I understand that's what the Army uses. No offense to those using others.
dowgars is offline   Reply With Quote
Old 04-20-2011, 05:20 PM   #3
Zeta's Avatar
I'm looking at a Mile marker VSX12 with the remote mounting control box. Should easily fit. http://www.milemarker.com/products/xseries.html
It looks like all the really heavy duty (15-16.5k lb) winches are foot forward mounted that will fit in the Aluminess bumper opening, but need to bolt to something besides the thin aluminum front of the bumper.
Z
'06 RB50 SMB Diesel
Old 04-20-2011, 05:46 PM   #4
Roonie's Avatar
Re: What winches fit Aluminess Bumper?
I know a bunch of folks use the warn M12000. It is about the same price on Amazon and Warn has an excellent reputation. I have been doing the internet research too and by all reviews point towards a Ramsey or Warn winch.
Someone did get a m16000 stuffed into the bumper and they had to relocate the box or turn it around somehow? However in a previous thread the point was brought up that it is still thin aluminum bumper material you are bolting too and with a powerful winch like a 16 you can damage your vehicle.
Old 04-20-2011, 06:27 PM   #5
Call Aluminess?
Old 04-20-2011, 09:22 PM   #6
I have a Mile Marker 12K on my Jeep. Solid but slow like a 56K modem. Don't know how it compares to the Warn 12K, my last Warn was a HS9500.
Old 04-20-2011, 10:17 PM   #7
REF
REF's Avatar
Send a message via MSN to REF
I have a warn 12K powerplant, with the built in compressor. I had a new cover made to fit over the winch. We were able to use the original lock with the new cover.
Old 04-25-2011, 09:27 AM   #8
Hello everyone,
It is possible to fit the Warn 16.5 winch in our front bumpers. I attached some instructions about how to clock the winch to mount to the current mounting holes that are in the bumper. We are very confident that our bumpers are able to handle the load of the winch mounted in that location. If you have any questions give us a call or send us an e-mail.
Thanks!
Kenny Gorham
Aluminess Products, Inc
619-449-9930
aluminess@sbcglobal.net
File Type: pdf Warn 16.5k winch clocking and conroller mounting.pdf (194.7 KB, 84 views)
aluminess is offline   Reply With Quote
Old 04-25-2011, 10:16 AM   #9
Is it safe to clock a winch that was made to mount feet first? I'm not clear on how it's ultimately mounted into the bumper- 4 grade 8 bolts at 4468 lbs each is barely 16K and that's straight shear, nothing complex.
But just fitting the holes and having strong enough bolts was never the issue as I understood it- the front of the housing case is made to withstand the force. If you clock it so the force of the drum goes against one of the other walls then you're defeating the purpose of the front feet mount, no? If Warn or other manufacturers designed the tertiary casing walls to withstand the full force of the drum under load- why make it foot first mount anyway, why doesn't Warn just put 6 bolts in the foot plate and call it a day? It would fit a lot more applications that way.
Old 04-27-2011, 04:15 PM   #10
You are correct about the sheer of the bolts when it is bolted through the bottom. We also provide a bracket that attaches the winch to our back plate with a couple more bolts. So in addition to the 4 bolts through the bottom, you also have 2 more bolts through the back. With this design the winch helps to strengthen the bumper by creating another spot where the bottom and back plates are tied together, and it also takes stress off of the four bolts that mount through the bottom.
We have put winches mounted like this to the test. One of our customers got buried in some thick mud on a beach up to his axles, and instead of digging he decided that he would just try and winch himself out. He broke the steal cable and had zero problems with the way the winch was mounted. Pictures of how stuck he was can be seen on our website here. http://aluminess.com/winches.htm
Warn makes foot down mounted winches in the 12k lbs rating that fit in our bumper with no problems. With one of those winches and a snatch block you can get yourself out of pretty much anywhere. Some people insist on a 16.5 winch so we did a bunch of research and came up with the solution above.
