Old 11-04-2007, 04:01 PM   #1
mmocken's Avatar
Send a message via AIM to mmocken
Winterizing
I was reading what to do...I drained all tanks, disconnected the pump out and pumped out all I can.
I still do not trust that all the water is out.
Any suggestions for filling the system with RV antifreeze? I was thinking of hooking up a small spray tank to the water in any pressurizing like a hook up.
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
https://www.sportsmobileforum.com/alb...a37caeae3a.jpg
mmocken is offline   Reply With Quote
Old 11-04-2007, 04:27 PM   #2
Apart from the propane hot water tank mine has a valve on the bottom of each line- for example the "city water" hookup has its own stopcock to drain the line. I'm not sure how much the previous owner changed and how much is SMB.
As for the hot water he used to drain by taking out the whole anode rod and according to SMB Texas they have anode rods with a stopcock built in (although somehow the old kind got put in my van when they replaced it)
So no antifreeze for me, just diligent draining.
Old 11-04-2007, 06:33 PM   #3
Winterizing isn't a big deal for me, living in SoCal and about 7 miles from the Pacific, but some trips do involve travelling to the mountains in Winter.
On one of my trips to SMB West, I was talking with Alan about my 6 gallon fresh water tank (my only onboard fluids aside from drivetrain lubricants). Alan recommended using a cheap fifth of vodka when "winterizing". No toxic antifreeze that way, and it sanitizes. Of course, there's always vodka on tap...
Old 11-04-2007, 08:38 PM   #4
Jeffrey's Avatar
I'll drink to that.
Old 11-05-2007, 07:55 AM   #5
mmocken's Avatar
I assume you then manually fill the fresh tank and use the pump to pump out. I'm just not sure the line from the outside to the pump doesnt freeze
I'm going to put the antifreese manually into the fresh tank, turn pump on and then fill lines. The hot water tank is 2.5 gals, so i'm not going to try to fill it with vodka
Thanks
Thanks, Marty
Old 11-05-2007, 08:28 AM   #6
It shouldn't have to be 100% vodka by any means. I couldn't tell you how much would be needed but I think a fifth in 2.5 galons would be more than enough. After filling the tank with Popov and water, you could drain some, and then capture some of the mixture iin the drain line.
Old 11-12-2009, 10:40 AM   #7
Mahukaawe's Avatar
Re: Winterizing
So if I add bottle of vodka to a couple gallons of water in my 17 gl tank then make sure it has gotten into all the lines including shower, that would be good?
09 E350 EB 6.0PSD SMB 4x4 kind of a 61 layout
02 F450 Flatbed 4x4 7.3 PSD
08 F150 5.4 ltr 4x4 Daily Driver
77 Orig Bronco in rebuild mode "uncut"
76 Orig Bronco rebuilt & driven weekly
71 Orig Bronco rebuilt & 4sale gots everything on it
Owned a jimmy once for about 6 months.
https://www.tropicalgardensofmaui.com
https://www.mauicabins.com
twitter @runnin6mpg
Mahukaawe is offline   Reply With Quote
Old 11-12-2009, 11:59 AM   #8
MikewTV's Avatar
Send a message via AIM to MikewTV
Re: Winterizing
To be clear, whether you're using vodka or RV antifreeze I don't think you are supposed to put either into your hot water heater. Just your pump, lines and tanks. The hot water heater is to be emptied and bypassed is my understanding (and how I've always done it.)
Mike W
Pueblo Gold Ford EB 350 v10 with EB 50 floor plan & Quigley 4x4 from Huntington (aka: Minerva)
MikewTV is offline   Reply With Quote
Old 11-12-2009, 10:53 PM   #9
Re: Winterizing
I used a shop vac with a small hose attachment this year on mine this year.
Took the shower head off and vacuumed out that line and also the HW tank through the annode hole.
At the end of last winter, I used vodka to steralize before refilling, not as antifreeze.
Old 11-13-2009, 10:55 AM   #10
Mahukaawe's Avatar
Re: Winterizing
What is the best ratio used with vodka and water?
We dont have a water heater so it is a bit simpler.
twitter @runnin6mpg
