I'm ready for my Fiamma. I live on the East Coast (Maryland) so I can't take advantage of a group buy, but still need your brackets. I have a 2007 Ford Sportsmobile. It is extended with a hightop. I am leaning towards the longer 350 vs the 300 but welcome your opinion. If need be, I took some pictures of the gutter that I can send you.
Thank you,
Carl
2010 Ford EB350 Sportsmobile/UJoint
Thanks Ray! My question is about height. My van is about an inch from the roof in my garage space (hence the need for these instead of just using a roof rack) so I'm wondering how high above the roof like these brackets and the awning go? I suppose worst-case scenario I could attatch and detach them every time I go on a trip? Are they built with one-time install in mind?
Hope this helps...https://www.sportsmobileforum.com/fo...tml#post267843
There is some tweaking to make these fit cleanly.
Since the gutter is an arc, I ground the tops of the front and back awning mount to make a straight line from front to back, to make the awning sit flush on the mounts.
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Yeah that totally answer's my question. There's absolutely no way that will fit under my low garage ceiling so I'd have to install the brackets and awning every time I leave for a trip (about 6-8 trips a year). How difficult would that process be?
It's possible to install and remove the brackets in a relatively short time frame.
I chose my particular mounting style to provide a permanent mounting system with multiple attaching points AND easy removal.
I'd probably search for another mounting style or just use a pop-up next to the van - https://www.amazon.com/Coleman-Insta.../dp/B0033990N8
It all depends on what you already have and how much space is available inside the van (pop-up) vs outside (awning).
Chris
Hi Ray, Are these brackets still available. Sorry if you are getting a second message on this forum, I also sent you an email the other day. Let me know what you need to order a set of Brackets. I have a 2010 e-250.
