Re: 120v AC from a car alternator?
Yes, in the video I think he got as high as 300Hz. Not a problem for the light bulbs he was running but definitely a problem for motors. But would it be a problem for a bulk/absorption battery charger? I know that Battery Minder uses a high frequency pulse for desulfation so it must be changing the output frequency, but does it expect/require 60Hz input?
I knew there must be a reason that the cpu/transformer on the Auragen was so big and heavy.
