Old 05-28-2008, 05:16 PM   #1
panion's Avatar
12v Auxillary condensor motor died. What part, where to get
Hey guys. My van is a 2001 with Starcool 2 or maybe 3. I have an auxillary condensor and 12v fan under the left side of the vehicle. The fan motor locked up and needs to be replaced.
Anyone know what part number it is, or where to get one???
Thanks.
2001 RB 7.3 Powerstroke 4WD.
https://sportsmobile4x4.blogspot.com/
panion is offline   Reply With Quote
Old 05-28-2008, 11:32 PM   #2
starcool fan
Contact the folks at Danhard, Inc., 214-328-8541 or www.danhard.com . The condenser is a model #00864, they'll know the exact fan you need for it. Good people to deal with. You can also see if SMB stocks a replacement fan.
FYI, it is not uncommon for pebbles to work their way into the fan shroud and cause the motor to "lock-up", use a water hose to clean it out. Also, the ground wire on the lower condenser fan is known to have corrosion issues, so make sure you double check it while you're in the area.
John K.
John Kalmbach is offline   Reply With Quote
Old 05-29-2008, 04:58 PM   #3
panion's Avatar
Thanks for the info John. Exactly what I'm looking for.
