Old 11-23-2013, 11:12 AM   #11
Re: 12V to three-prong inverter doodad - looks useful
So has anyone found a quality 12V inverter/USB converter? I had one that lasted about 6 months and am looking for a replacement. A lot of them have a huge number of USB outputs, but the total current available doesn't change so all you end up with are a bunch of USB outlets that don't provide enough power to charge your devices. More and more USB devices need 2.1Amps to charge.
A cigarette lighter provides something like 7A-8A total, in a best case scenario?
I'd stick with the single 12v models (some have a couple ports like those for my Go-Pro cameras). They just drop the voltage and you don't need to run an inverter unless 120vAC is needed. My ToughBook has a dock that is wired into 12vDC but sometimes I use it as a DVD player off the dock. I was surprised how much those little power port inverters actually pull. I bought a high quality 12v adaptor for my Toughbook and it uses less that the micro inverter plus I don't have to worry about a crappy modified sinewave.
Guster
Salmon
Wanderjahr
wanderers
