Old 03-07-2010, 08:02 PM   #1
AIMS 1500 Watt Inverter/Charger Opinions
I am looking into this unit and was curious if anyone had any opinions or experience using it: http://www.invertersrus.com/inv1500wc.html.
Basically I have a 300amp hour auxiliary battery bank and am looking for both an inverted and a charger but have a very limited budget. Will this device be sufficient for charging the batteries when the vehicle is not running? If I am running a 12V load off the aux batteries will this keep them topped off when connected to shore power? I understand that the AC power will "pass through" powering my devices when plugged into shore power, but am not sure about the DC load.
Thanks
thuynsm is offline   Reply With Quote
Old 03-07-2010, 10:21 PM   #2
Re: AIMS 1500 Watt Inverter/Charger Opinions
What is best for charging is a multi stage smart charger. The unit you posted about will work fine just that it might have a tendency to overcharge is some circumstances. High end chargers also monitor the battery temp which can be critical during hot weather. If price is a goal, having a standard inverter/charger is OK, you just have to take some precautions. Also that inverter is a modified sine wave type. Great for most everything except high end electronics. I would like to have something similar as a backup inverter. Maybe down the road you can spring for an upgraded version.
Dave.
Dusty
capnkurt
PolarVan
PolarVan
