Old 06-11-2012, 06:03 PM   #1
haywoodphotomaccom's Avatar
Alarm Info?
Thought I saw somewhere here of an alarm type system that made the vehicle immobile when a key or plug type device was removed. Tried a search here with no luck. Anyone have any info on such a system.
If I remember correctly it was very simple.
Thanks in advance.
Brent
2006 Quigley V-10 (Sold)
Old 06-11-2012, 06:47 PM   #2
BIGVANS's Avatar
Re: Alarm Info?
Is this it?
http://www.ravelcosecurity.com/ravelcoinfo.html
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-11-2012, 06:49 PM   #3
Gnarvan's Avatar
Re: Alarm Info?
Brent
You could always install something like this under the hood somewhere.
http://www.rallylights.com/detail.aspx?ID=962
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-11-2012, 07:03 PM   #4
Re: Alarm Info?
Originally Posted by BIGVANS
That's what I had installed on my SMB, and what I had installed on my Excursion just after I bought it.
Old 06-11-2012, 07:06 PM   #5
Re: Alarm Info?
Thanks Gentleman, Ravelco was the one I was thinking about!
Brent
Old 06-11-2012, 07:35 PM   #6
Re: Alarm Info?
I have one installed and use it religiously. Once you get in the habit you don't even think about. I have the plug to the left of the steering wheel and below the lower dash so it hangs down. If you do it there be sure to have it clear of the parking brake travel and your foot has room to operate the P.B. Mine is just barely. If I had to do it over I'd have it put in the dash but that does complicate removing that panel as the install tech said. Pricy but worth it the peace of mind.
Pat
PatO is offline   Reply With Quote
Old 06-11-2012, 07:48 PM   #7
Re: Alarm Info?
What was the cost? No pricing on their website.
Brent
Old 06-11-2012, 07:54 PM   #8
Ultrasport12's Avatar
Re: Alarm Info?
There used to be a few of the types of thing you are talking about. They were usually installed near the ignition switch and you inserted a key into a slot to start the car. Quite Popular back in the 80-90s.
You can kill the van from starting a bunch of different ways like installing a hidden switch for the fuel
pump or ignition system. You can also do it so it blows a fuse if the switch is not turned off but if you forget that is kind of a pain. I used to do that for my boats when they were in the water. For something simple you can just take the fuel pump fuse with you. I think on your van (gas) it is fuse F13 20 Amp Large Size Fuse in the Battery Junction Box under the hood on the drivers side. And F6 20 Amp Small Size kills the fuel injectors. My wiring diagrams are for 2008 so they might not be the same.
Most newer alarm systems (especially ones with remote start as well) can be wired so if they are armed the vehicle will not start no matter what wires you cut, they would need to be spliced to be able to start. My alarm has starter and ignition cut, two way remotes that lets me know if anyone is tampering with it up to one mile. You can also get Cell phone modual that connects to your phone anywhere you or your van has service. You van can be at home and you could be in Florida and if anything happens it will let you know. It does have a monthly service charge however.
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 06-11-2012, 08:17 PM   #9
Re: Alarm Info?
Off the top of my head, I want to say it was right around $400 installed, including the AAA discount. One nice thing, is that they come to you to install it.
Old 06-11-2012, 09:14 PM   #10
Re: Alarm Info?
I agree, somewhere between $400 & $450 with AAA discount & 2 plugs. I also got an extra plug for $35 after the fact. I'm surprised pricing isn't on the website somewhere.
Vandemic
Charliesmom
Turtle
rafeman
