Brent,
I want to thank you for posting about this product, it is always nice to get some real feedback on some of these products. I do appreciate you taking time to do this. It is encouraging to see that you are getting better performance out of set up then before. I suspect that the 4 to 5 times the charge rate is a best case condition, and may never be met by your set up. First the charge rate will be predicated by your level of discharge and size of your battery bank. Second, you may and probably are still limited by your current alternator. In this case I am assuming you have the standard V10 115 or 135 amp alternator. The amount of current that this unit will provide will still be limited by the output of the original alternator. In fact the maximum that it provides will be somewhat less because of the conversion factors involved in the charge algorithm.
I will try to provide my interpretation of the unit (based off of reading the documentation, as I do not have one). First, this unit is really a couple of devices in one, and could possibly simplify some (especially new) installations. First, it does away with the need for a separator or isolator, as this has a split diode isolator built in. The second part of the unit a more like an advanced regulator for the alternator, this allows it to perform much like a real 3 stage battery charger Bulk, Absorption, and Float cycles. This is the real plus to the unit. So you may wonder how it actually get more charge out your alternator and provide all these wonderful features. In the simplest terms it make your alternator work harder, by pulling down the alternator output voltage, this makes the alternator work much harder, just like when you turn on your headlights, megawatt stereo, air-condition, etc. It also has some nice options like battery temperature feedback, remote sensing, and a remote control that lets you monitor the various currents and voltages.
Pros
- • Eliminates the need of a separator or isolator
• Eliminates the concern of battery technology mismatches, it provides different voltages and current to the house (domestic) and the van starting batteries
• Turns alternator into 3 stage battery charger with optional temperature compensation, and remote sensing.
• Multiple battery type settings for house (domestic)
• Does not affect PCM
• Maximizes power provided by alternator
Cons
- • Makes your current alternator work harder, most likely producing higher temps and earlier life failure. They do provide an optional alternator temp sensor, and also have a built in software timer on their boost mode.
• While this will improve the charging characteristics of any alternator it will not make up for a undersized alternator. If you are having issues when running high current devices.
I am sure there are other things that I missed.
E350, if you already have an option for a second alternator then you could just use their alternator regulators since you could isolate the starting system with the second alternator and get pretty much the same thing.
