Re: Alternator went bad in a year
One thing to check for is if the separator is wired correctly. I believe that some of the early separators may have had the start assist wire going to the run circuit instead of the start circuit. So instead of engaging while you are cranking, and then coming out of assist mode it stays on the whole time your running. This is not a huge deal, but if your house battery was low, it will have to charge both at the get go. If wired correctly the starting battery would get charged for a while first, then the separator would engage to charge the house. If you were to add in a bad starting battery this would add to the load of the alternator.
