Old 02-11-2017, 11:42 AM   #1
Anyone using a Smart Plug for shore power?
Seems like a better cord all around, but could see it as one of those things that solves a problem that doesn't exist.
30 AMP RV Cordset - 30ft -
Wrinkledpants is offline   Reply With Quote
Old 02-11-2017, 02:56 PM   #2
pugslyyy's Avatar
Why wouldn't you just use a standard RV/marine L5-30P inlet?
pugslyyy is offline   Reply With Quote
Old 02-11-2017, 03:45 PM   #3
Sure,
A couple of us for sure. The reasons are pretty much profided in this thread. http://www.sportsmobileforum.com/for...tor-17137.html
Old 02-11-2017, 04:11 PM   #4
Sure,
Awesome - that goes along with my experience using connectors like that with industrial equipment.
Will request SMB uses the Smart plug for our Sprinter build.
Old 02-14-2017, 01:41 PM   #5
I installed a smart plug on my boat after finding the 30a twist lock partly melted, but discovered that I never unplug it, so it could have been hard wired instead. My van is hardwired, the cord is stored behind a small plastic door, so there is no danger of an inlet plug melting. I simply open the door and pull out the cord as needed. If you have a similar set up, hardwiring makes sense, but if you need to be able to remove the cord after each use, the Smartplug is a great improvement.
Old 04-14-2017, 01:13 PM   #6
Smart plug
Hi. While I am not affiliated with smart plug, I use to work with one of the co owners of the company. We worked together on university of Alaska's research ship. He was the chief engineer. Really smart guy.
He brought us some smart plugs to use for our tender's battery charger and our life boat block heaters . They are really nice products and really well made. They are more expensive but they will last forever and highly weather resistant. Ours are constantly getting spray seawater and they show no signs of corrosion or damage.
So yea they're really nice but yea they are a little expensive. He always talked about how they're supposed to be much safer and better at minimizing potential fire damage than a regular plug. Something about the electronics built into the plug
MRR918 is offline   Reply With Quote
Old 04-14-2017, 08:47 PM   #7
LenS's Avatar
So what is a typical price for a male and female retrofit set ????
Len & Joanne
The Green TARDIS
Old 04-15-2017, 02:16 AM   #8
I really have no idea
Old 04-15-2017, 08:12 AM   #9
LenS's Avatar
SmartPlug 30 Amp Connector & Non-Metallic Inlet - White
$146 at this site.
I got a better search with "smartplug" not "smart plug"....:-)
Len & Joanne
The Green TARDIS
Old 05-21-2017, 09:09 PM   #10
pugslyyy's Avatar
A few posts up I asked why you would want one of these fancy shmancy plugs. Looks like I answered my own question...
Sent from my SM-G935V using Tapatalk
