Originally Posted by Jsweezy
You could always just unplug it underneath the rear bumper.
J, I see the cam on the license plate area. Is the actual sensor underneath the bumper somewhere?
Originally Posted by MadScience
I'd figure out how to move the sensors. You may need coax or twisted pair if you need to lengthen any of the connections.
MS: same question, is the sensor actually somewhere not near the cam?
Originally Posted by shadetreevanman
On my 2012 E350, you can turn off backup sensors (not the cam, they are separate devices) in the odometer settings. Click the odometer button until you get to that setting and select OFF.
It resets every time you turn off the ignition. I'm going to go deeper into the settings and see if there's a permanent "Off" setting. But if I could move the sensor itself and still have that backup warning function, that would be cool.
