Old 09-26-2017, 10:07 PM   #1
Blowby's Avatar
Battery charger 15amp 110v van outlet?
Ok a question for those that may have a solution.Presently I have a battery charger inside the van under the couch which has a typical plug end.I would like to be able to charge the battery through that charger without having to run a extension chord through an open door or window.
Would like to be able to hook up battery charger from outside the van.What would you suggest connector wise.
Have been looking at Marinco connect charge mounts, which are marine outlets.Are there other possibilities that I should be looking at.
Thanks
Blowby is offline   Reply With Quote
Old 09-27-2017, 10:17 AM   #2
somewhat related.........I have the same charger/converter....
Do you have the Charge wizard for that charger? The charge wizard turns it into a smart charger from a dumb charger. It's beyond me why the charge wizard module isn't incorporated into the charger.....
Old 09-27-2017, 10:30 AM   #3
Thanks
You won't get better than this:
RV Market - Smart Plug
Old 09-27-2017, 12:00 PM   #4
Blowby's Avatar
Boywonder I do have that charge wizard.
Old 09-27-2017, 12:01 PM   #5
Blowby's Avatar
Arctictraveller that is exactly the type of outlet I am looking for.
Thanks
Roger
