Ladies and Gents:
Wilson is wired with the starter TOTALLY seperate from
Xantrex and Blue Sky Solar controler
Starter ONLY recieves from Alternator
Alternator DOES have a Isolator to charge House batts
(fyi- this is what i spec'd, i did not wire, i will trace on wed when i final the rebuild)
Blue Sky Solar controler charges my House batteries
1- 4d with 210 amps
2- Group 27's(?) with 100 amps each
- not ideal batt bank but all i could squeeze in
- i understand and have convo's with various vendors re: mixing batt sizes and possible wiring for charging
Xantrex according to the lititure from the orginal build
has a charger.
- when on the Sample Meadows shake down i took a voltage reading before Sa'more time
- ran the Yamaha @ 2 hours
- no gain in voltage
THEREFORE:
a) xantrex not wired correctly to charge
b) there is sime button to press to make it charge
c) the charger portion no longer works
d) i need new glasses
Needed at this point:
1) hard wired seperate charger reccomendation
2) need to test test/trace the wirking currently in place
