Originally Posted by rogers112869
I have been noticing that my deep cell battery is not charging when my vehicle is plugged into my house. I tested my 45amp installed battery charger/power supply by removing it and plugging it directly to another battery that was low and it began charging. When I connected back into the SMB to the ground then the isolator, it does not charge that low battery.
Solutions? I found out its a TODD ENGINEERING 45amp model.
Not sure how you're connecting this - your battery charger shouldn't be hooked to the isolator, but it may be that we're each using different terms. On the DC side, it should have two fat wires going directly to the battery (positive and negative). On the AC side, it sounds like it has a regular three-prong plug. Try plugging something known to work into that same receptacle, to make sure there's power at the plug.
Cheers,
Mike.
