Old 07-25-2011, 12:22 PM   #1
CaveCreeker's Avatar
Battery recommendations
The summertime blast furnace of Maricopa county AZ area tends to give cause to very short battery life.
What are the most recommended batteries for a 2006 6.0? We are not campered out just yet but do have video monitors in the ceiling (4) & HID head lights (white not blue). Currently running 2 marine grade batteries that run low real quick if they are experience extended cranking. Thank you for your battle tested responses.
CaveCreeker is offline   Reply With Quote
Old 07-25-2011, 12:58 PM   #2
Re: Battery recommendations
I just went with duralast gold top in the van. Marine aren't really for starting, I ran a Optima marine in my Jeep and it caused problems (of course so does the Optima Yellow top I replaced it with...)
Old 07-25-2011, 08:15 PM   #3
I prefer an AGM but you have to look into quality as a factor. I figure having similar batteries in both starting and house helps a bit with similar charge characteristics. I avoid sealed or vented wet cells because they are hit hard by heat. Basically they're a PITA to deal with. So I've gone AGM all around. The correct move? Really I don't have a clue. For me, time will tell. Lifeline makes a great house battery in 4 or 8D series. Starting? I went with Odyssey but they also make batteries for Sears and those are worth a look for the price.
Old 07-25-2011, 10:22 PM   #4
mbachani's Avatar
Hello Jage,
I've been using an Optima Yellow Top as a Starter Battery for 3 years now. No Problems so far. Should I be knocking on wood?
Bob in Tucson
2003 Ford V10 4x4
Bob
mbachani is offline   Reply With Quote
Old 07-26-2011, 12:51 AM   #5
REF
REF's Avatar
Send a message via MSN to REF
Are you wanting a starting battery or a house battery?
I am running a yellow top for my main starter and like it, so far. If you are looking for a separate house battery I too would look at getting an AGM 4D or group 37 i think it is, Lifeline are very good and very expensive, I just got an East Penn AGM group 37 for my trailer, they make Deka, made in the good ol' US of A I believe.
Old 07-26-2011, 07:15 AM   #6
Originally Posted by mbachani
Hello Jage,
Bad phrasing, the blue top is probably fine but it wasn't charging in the Jeep. The yellow top has been without issue, except that my alarm still doesn't work- which I attributed to the failing blue top, so the yellow bears the brunt of that blame unfairly. In addition I've heard lots of anti-Optima in the past few years so while I put bought it for my own Jeep, I'm hesitant to laud them (or put them in the SMB as starters).
Old 07-26-2011, 08:33 PM   #7
cygvan's Avatar
just thought id mention...i found a local (to me) supplier of deka batteries. im going with their 4d agm's. what a pleasant surprise to find the place after searching the internet for batteries and seeing the shipping cost. best price on a 4d i found was from arizona wind sun at $312 before shipping. which was like almost buying another battery since arizona to nj is faaaaar.
i was quoted $380 for each deka 4d. no core but they accept battery scrap at .20 lb.
if it werent obvious to everyone, i would look locally. so if you are in nj (all 3 of you lol) company is atlantic battery (formerly power systems) located in paterson, nj. website here (very basic as they are reorganizing the company) http://atlanticbatterysystems.blogspot.com/
gentleman i met with was bill rasmussen and he was very helpful
Red Zeppelin - 2003 Chevy Express 2500 6.0L 2WD RB
cygvan is offline   Reply With Quote
Old 08-03-2011, 08:17 AM   #8
Velogeo's Avatar
Send a message via MSN to Velogeo
I haven't used them yet so I can't vouch but I came across some new AGM batteries at a local supplier (Boat Electric here in Seattle) while working on some other projects. The Energy One batteries look really promising. They come in a few different capacities and some interesting sizes. If you want to install them inside the van they're designed so you can easily vent them to the outside. When it comes time to replace my house battery I am going to look at using two or more of the Energy One's.
2007 6.0l 4x4 "Betsy"
Velogeo is offline   Reply With Quote
Old 08-03-2011, 10:11 AM   #9
dhally's Avatar
This is a great find for my build! Their Group 31 battery appears to be a full inch shorter than other Group 31's, with the same amp-hour rating. Yet it weighs 10 pounds more (more lead?). I will definitely be looking in to this battery.
2009 E250 RB 5.4L "SilVan"
Old 08-03-2011, 02:12 PM   #10
ANZAC's Avatar
For starting batteries, I've had good luck with Duralast Gold, and Interstate Mega Torque Plus (MTP-65?).
I've given up on Optima.
Sportsmobile-less.
