Old 01-13-2013, 10:57 AM   #1
Block Heater Plug
Where is the block heater plug/cord on my Ford 2007 eb 350 Diesel. Found it once long ago.... It is now minus 13 here in the morning!
IronTepee is offline   Reply With Quote
Old 01-13-2013, 11:06 AM   #2
Re: Block Heater Plug
Mine is just behind the radiator under the chassis. If you crawl under you should be able to find it. Not sure if they all have them though.
Old 01-14-2013, 03:01 PM   #3
My 2007 has it zip tied to the front axle, almost in the center (right to left). I used it every night while in Brian Head where it was -4 to -10 each night. Worked really well for the engine oil temp and radiator fluid. Both were in the mid to high 60's when I started up the van each morning. However, the transmission fluid was really cold and the van felt sluggish until that warmed up. Good luck and stay warm.
Old 01-14-2013, 03:37 PM   #4
Thank you both for the tips - I will check today - will be down to the minuses again tonight!
Old 01-14-2013, 05:19 PM   #5
You don't need to have the heater on all night. It will reduce your electric bill if you get a timer and have it come on 2-3 hours before you want to start the vann
Old 01-15-2013, 01:02 AM   #6
Pschitt's Avatar
A question from the newbie I am: do all E350 have a block heater plug or is it an OEM option?
Old 01-15-2013, 10:13 AM   #7
All diesels came with a block heater. I think it was an option for gas engines.
Old 01-15-2013, 10:28 AM   #8
Pschitt's Avatar
Thanks Mike
Old 02-20-2013, 11:02 PM   #9
On my 2008, the heater plug is laying inside the center opening of the front bumper.
