Good discussion on the wire size. Was going to buy jumper cables from Home Depot to use for my wire. Turned out they were copper clad aluminum.
Re fuses: IIRC it is not the house load that you have to size the breaker for. It is the short circuit amps. The Blue Sea calculator has you input the battery CCA so it can size the fuse.
Larrie
