Originally Posted by J.Spicoli
Anyway, I'll tell you what I'm doing but I don't have a diagram. What are you guys using to draw up your wiring diagrams?
In my case.....nothing.....I just wired the starting and house batteries together with a Blue Sea ACR and a couple of circuit breakers then connected a couple fuse blocks on either side of the rear of the van for power distribution.
The whole thing evolved/morphed along with a few other things during the build, like when I ended up with the neighbor's leftover charger from his RV...that's when I added the shore power plug.
The solar connects to the battery with a simple fuse, just like the diagrams above. Since my solar controller is located next to the fuse block, it's connected to the +/- battery there since there is no reason to run another pair of wires to the house batteries.
So I have the Lifeline 4D and 300w Renogy MPPT solar kit. I will be connecting the starting battery to the house battery through the BlueSea 7622 via 2/0 gauge wire ( Amazon link for the wire), I have both red and black. I'm also using a BlueSea 5026 fuse block to connect my two lights and a couple accessories. To help monitor the system I have a Xantrex link lite.
Your choices above look sound to me......depending on your build complexity you may need another one (or two!) fuse blocks......probably a good reason to make a wiring diagram!
Are you planning on an incorporating an inverter?
