CB Install, where to get power?
Pulled the CB and overhead console, the house power above (big red and white wire) are attached to the Fantastic Fan and the CB. The problem is the CB has had really dirty power and I've had a lot of problems. If it's not the house line or the fantastic fan, then it's the wire extension... looks like lamp cord, not regular automotive wire.
So- I either need to figure out which part is the problem (fantastic fan, lamp cord, house power itself) or just run a fresh power source up for the CB. Is there a good source I can tap into, that is relatively easy to get to one of the A pillars?
Is there a way to test the power/eliminate something or clean it to get the CB fresh power?
