Originally Posted by xcnick
Originally Posted by 86Scotty
This should help
Yes, very good. Did you ever build more for other things like the links levelers etc.?
Your thread has good pictures to take to someone if I want to have it fabricated.
I will start at Pic and Pull wrecking yard. It will give me a chance to look at other things. I see you like this sort of thing as well. I am looking for a step bumper and little things. Sometimes I just disassemble things to make sure when I do it for real on my vehicle I won't breaking things.
My van had the factory passenger side battery box. It is made for a Group 65 battery. It does need to be unbolted but it is designed to swing down pretty easy and has cable to stop it from falling on the floor.
It will hold a Group 27 battery (barely), but would need to be lower to allow for the taller Group 27 on the passenger side. Which would reduce ground clearance.
If the van has factory rear AC, the hoses will be in the way of a battery on the driver side.
I did a lot of internet searching and could not find any other battery boxes. I think fabrication is the way to go.
