Originally Posted by Scalf77
So switch the ground so the Surepower it is connected when parked and you will charge and maintain both batteries. You do enable the switch after you start the engine? correct?
On the otherside your controller does have a 2 amp aux battery charge output, I would probably hook it to starter side of the surepower, if you insist on using it.
Correct, I can throw the switch and reconnect the ground so the solar will charge both house and van batteries. Since I'm a forgetful simpleton, the problem is that I won't remember to switch it off when I need to drive the van every time. That's the part I want to fix by hooking the trickle charger to the van batteries.
And no, I do not reconnect the ground after the van is running. The alternator is charging the van batteries at that point, while the solar takes care of the house batteries.
So I gather from your second statement that I can just run the + connection for the trickle charger to the van terminal on the 1315, and not have to run wire all the way to the van batteries? But where do I run the - connection? Can I just hook it a solid ground to the body or frame? The wiring diagram in the Blue Sky manual indicates that the wires are directly connected to the battery posts.
