Old 12-10-2016, 01:31 PM   #1
Digging in to the dash wiring
Digging in to the dash wiring today with the ultimate goal of installing my new stereo equipment. The previous owner(s) of my van seem to have gotten pretty creative in the past. There is the remnants of an alarm system as well as a very questionable previous stereo install. In the wake of all this I found a few connectors which are not, well... connected. Perhaps the brain trust here can help be identify them.
1997 E350 EB Cargo 7.3
It looks as thought the grey plug in the background attaches to the yellow unit in the foreground. Anyone know what this is? (located above and to the left of the doghouse)
motoidiot is offline   Reply With Quote
Old 12-10-2016, 01:33 PM   #2
Next up, this one is just loose behind the dash. Disappears into the stock wiring harness.
Old 12-10-2016, 01:34 PM   #3
Finally, this is mounted to the dash frame beneath the stereo location.
Old 12-10-2016, 01:51 PM   #4
gcvt's Avatar
Photo #1: No idea.
Photo #2: Looks a lot like the connector for the cigarette lighter.
Photo #3: What a mess. Never like to see wire nuts in cars.
Greg
New van: 2003 E250 EB10
Old 12-10-2016, 02:19 PM   #5
Flux's Avatar
No ideas either, but ditch the wire nuts quick and use crimp connectors. They don't vibrate loose.
Old 12-10-2016, 02:24 PM   #6
Originally Posted by gcvt View Post
Photo #1: No idea.
#2, I think you're right. I had it stashed up through the cigarette lighter hole but it slipped down.
1 down, 2 to go.
Seriously considering paying a "pro" to sort this out and put the new head unit in. Worried I would get another, similar install though...
Old 12-10-2016, 02:32 PM   #7
1) Possibly the door & warning chime module?
2) AUX power point connector. Should be 12+ & ground, switched with ACC position.
3) Looks like a stereo system "ISO" connector. Somebody maybe had a really nice system at some point. https://www.aliexpress.com/item/Fema...08.4.38.vXyE5w
Old 12-10-2016, 02:35 PM   #8
#1, I wondered if that might be the chime module. My van doesn't let me know when I have doors open, seat belts unbuckled or (most annoyingly) when I've left the lights on.
Old 12-10-2016, 02:43 PM   #9
gcvt's Avatar
^ I think you're right Mike. A quick search brought up an exact picture as being a "Warning Chime Buzzer Module 1992 Ford F-150"
Greg
Old 12-10-2016, 08:25 PM   #10
I second the idea that #3 is a stereo connector.
I just put a new unit in my 1996 e350 and it had two of those connectors. The other connector was gray and contained the speaker connections. The connector you found should contain a 12v always hot (for stereo channel memory), a 12v wired to the ignition, a power antenna wire, a ground, and maybe one additional that I don't recall offhand. A multimeter should confirm this quickly.
This adapter could be used if you wanted to clean things up. (Check your year, '96-97 may have been a dash changeover.
Metra 70-1770 Receiver Wire Harness Connect a new car stereo in select 1986-2006 Ford and other vehicles at Crutchfield.com
bcaine is offline   Reply With Quote
