Originally Posted by Viva
I don't know where you are, but I have a big crimper and could potentially make/send you a cable,
Originally Posted by xcnick
I am in Lake Tahoe. Just added that to the profile. I would love to work with someone. Mind if I sleep in your driveway. This forum is the only thing that keeps me from feeling like I am alone in this endeavor. The crimper would be great. So far my plan was to use a propane torch to solder the ends on.
Ooh, nice area! Going up 395 (and offshoots) is one of my all-time favorite drives. I totally hear you about working with someone. I often end up doing projects alone, and so many times another pair of hands (or another brain to noodle with) would be so great. Or just the camaraderie even if the other person were only working on their own project but side-by-side. I'm actually out "on the road" in AZ right now, so no driveway, sadly (or you'd be welcome). I do have my crimper along though
I met up with Scalf77 when I was up in Oregon, and he helped me out with "visualizing" quite a few electrical details that I wasn't entirely sure of, plus showed me how he did the "non-heated-vents" mod (on my list). It's great that there are so many knowledgeable and helpful folks here.
I bought this '96 Sportsmobile with 45000 miles for $9,500. This left me room to drop more into it which has been documented on this forum through my questions. But at first glace it would take $9,500 to do the electrical like I dream of and that doesn't make sense for something this old.
Ooh, nice buy. And low miles! Mine had the same stripes but in teal (whee!) I hear you on the project costs though. My '97 was also a "deal" (but had nearly 100k on it and needed tires), and my mission statement for it was "for ONCE in your life just buy something and USE it, without taking ages tearing it completely down and re-doing it, For Pete's Sake." I mostly held to that, although of course I did maintenance, tires, spark plugs, etc. Ironically, a friend of mine bought it from me and then this winter came down to AZ where we just spent a few weeks doing some of the projects I had really wanted to do on it (300 watts solar, MPPT controller, 250 ah of AGM house batteries, battery monitor, re-vamped DC distribution system). Now he can run the fridge full time whereas I had to either plug in or keep a move on (always driving to charge from alternator - through that #8 wire, LOL, good thing I never looked to see how small it was -- kind of knew I shouldn't look too closely). Funny thing is that now the SMB it has 140k on it and my buddy didn't deem it "unworthy." But I know what you mean: That can be one of the irritations of having an older rig, i.e. deciding that things "aren't worth it" and so going without them. Of course it is a real consideration.
I/buddy haven't added up exact figures, and I did have a lot of the "nickel and dime" stuff (tools, wire, lugs and ring crimps, shrink tubing, cushion clamps, stainless fasteners, etc.) left over from another project, and I'd say the project materials that he did have to buy ran somewhere around $3,000 or so (labor was free
) By the way, I asked him and he said it was fine for me to discuss the project/details here on the forum. Here's how I get that figure, just off the top of my head. I may be forgetting something.
Three 100-watt panels, shipped: $450
Blue Sky MPPT controller (25 amp), with built in shunt/battery monitor/remote display: ~$500
Aluminum angles and etc for roof mounting, plus paying shop to cut and polish them: $100
Blue Sea Cable Clam: $25
Blue Sea On/Off switch (to shut solar panels "off"): $25
Two Lifeline GPL 31XT batteries, shipped: $750
Bus bars, fuse holders, fuses, breaker, etc.: ~$400
Blue Sea fuse block = ~$50
8' #4 cable (I didn't have any of this size): ~$25
A Blue Sea 7622 would have added around $200 to the project, and wire/lugs would also have been a chunk, if we hadn't had "stock" lying around. Also this SMB is still fairly simple, with no Inverter or related systems.
But yeah, it took time and money. The nice thing was that the learning curve was small having just done a similar project on another friend's (non SMB) RV.
Let's just hope I can stay out of airplanes
PS: If you really do want to use #6 wire, I can simply make you up one and send it if you let me know the length and what size ring terminals you want on each end. I'd probably go to larger wire, but even #6 is a lot bigger than #8 (or 10!). I don't have #4 on hand. Might have enough #2 but not sure. It would probably have to be black vs. red (I always end up with extra black wire due to the runs with chassis grounds only needing red!). In #6 I could dig up red, I believe.
Thanks for the links to your travels, etc. Going to go check them out.
