Old 07-03-2019, 01:26 PM   #1
Dome and Door lights stopped working E350
On my last trip my dome and door lights stopped working. Everything else on that fused circuit still works (instrument cluster, and stereo), and it seems like the door switches must work as well since the stereo turns off when you open the door (like normal). Any ideas? Vehicle is a 2007 E350 V10
Thanks!
sierraoneill is offline   Reply With Quote
Old 07-03-2019, 04:27 PM   #2
oldbonesclimber's Avatar
You may have pushed the button to turn off the light at the light fixture. I keep mine turned off except when I want it.
oldbonesclimber is offline   Reply With Quote
Old 07-03-2019, 04:40 PM   #3
Twoxentrix's Avatar
Lost both dome lights at the same time a year ago. Truly no intention here of coming across insulting, but have you check the bulbs?
Old 07-04-2019, 12:28 AM   #4
I have not checked the bulbs as it is several lights not working (LED's included).... All door lights (lights at the floor panels) will not light.....(passenger, driver, barn doors and rear doors)... so it;s a bit deeper than that..There is no button to turn off all lights including Dome lights on my van that I am aware of...... Dome lights are dead both under Driver and Passenger seats as well as in the back at the rear doors. Some Relay I might be missing???
I was on a parasitic draw search a few months ago which was solved, and in the process replaced both relays deep under the dash (Battery saver and some other... cant remember but same P/N )... This is pretty is an odd one since everything else on the circuit is still live (radio and Instrument panel). Fortunately its totally something I can do without and really care less about...but the OCD about it not working makes me crazy!!!
Big Backpack
RMAC
Hermes
Nimzero
