[quote For the sake of simple math, if I draw down my house batts 50%, that would be 175ah. If my stock alternator outputs 120 amps, that's about 1 1/2 hours of driving to charge them back up...It also needs to charge up the starting battery after each start so a little more.
Actually, it will take quite a bit longer to bring your batteries up to full charge as the acceptance rate (the amount of current the batteries will accept) goes down as the batteries reach about 80% charge level. This is why good regulators have three steps, bulk, absorbsion, and float. The first 80% or so of the recharge cycle will go quickly, but then the charge rate begins to taper off quite a bit. The absorbsion phase can take nearly as long to finish off the final 20% as the entire bulk phase took. The result is much longer times to 100% charge than you would suspect. What often times happens is that batteries are not fully recharged between uses resulting in a shorter life span.
As for running two seperate alternator's that are isolated, I see no reason this would not work, but unless you have huge draws on your system, having 400 amps worth of potential current seems like a lot of overkill. I would think, with enough engine hours, one big alternator would work fine to charge up even the biggest banks, as the maximum usable current will fall quite a bit after a while. My boat has 1800 amp hours worth of golf cart batteries (12 6Vs), one 60 amp alternator to recharge the start batteries, and one 100 amp alternator for the house system. I'd like to have a bigger one, but I'm limited to one Vbelt. Still, because we motor for many hours a day, often times the one house alternator is enough to replace all the amp hours used overnight. If we don't motor enough, I simply run the gen for a while to power the shore power charger.
If you install one big, high quality alternator with a seperator or some other method of cross connecting all the batteries, you would save a lot of money and time. If your looking for the ultimate in redundantcy, then two might be one way to do that. Another reason might be to have different charge parameters for different battery chemistrys.
For folks interested in learning more about 12v systems there is no better book available than this one. It's written in simple, easy to understand language. I recomend it to all my assistant engineers as a great referance and refer to it myself often..
http://www.amazon.com/gp/product/007...1&sr=8-1-spell
