01-23-2015, 09:39 PM
#21
Re: Dual Voltage (12v dc / 120v ac) Small Electric Water Hea
Hope this works. Thanks for testing it!
Eric
01-23-2015, 10:33 PM
#22
Dude!!! Thanks for showing your homework! I may learn something!
01-24-2015, 08:31 AM
#23
....a few other considerations........
a 300W 12V heating element draws 25 amps of current, so a 600W 12V element will draw 50 amps (and heat the water twice as fast).
In either case above, you'll need to provide wiring and fusing large enough to support the load. This means at least 10 AWG wire for 25 amps and 6 or 8 AWG wire for 50 amps.
In my case, there is no way I can support the 50 amp load, so it'll be a 300W heating element or less. There appears to be 200W 12V elements available also.
...and finally, a lower wattage element will be intrinsically safer in a failure mode, since there will be less energy going into the system. For example, let's say the thermostat fails closed (very low probability of this, but we are analyzing failures here) a smaller wattage element will result in a lower "over temperature" condition since the element is adding heat at a slower rate than a larger element and the heat lost through the jacket insulation will be (close to) the same with either element.
01-25-2015, 04:51 PM
#24
My dual 12v/120v instant hot I have in my traverse says it takes 15 mins to come up to temp with120 and ½ hour for 12v ..
2002 E250 5.4 4R70W 2wd 3.5 inch lift Pleasure-Way Traverse on 16x8 with 265/75/16's
01-25-2015, 06:05 PM
#25
An "instant" hot water tap that takes up to 30 minutes to get hot? Hmmm...
01-25-2015, 08:58 PM
#26
The label says capacity 1/3 gallon, so it must have a fairly low wattage element if it takes that long to heat up.
......senior moment.......directly above the "1/3 gallon tank capacity" it says 12VDC @ 8.3A...
Mr Ohm says P=VI so 12V*8.3A=100W element.
01-26-2015, 12:45 PM
#27
T
Yes they have start up period .once that is over it is more less "instant"
01-26-2015, 03:54 PM
#28
reelchef67 and boywonder: To me it comes down to capacity. I will likely drive more than 30 minutes to a camp spot so both units will be adequately heated upon arrival. The storage tank type will have 2.5 gallons of usable hot water while the instant on variety will have 1/3 gallon of usable hot water. So, unless I am missing something, the storage tank type hot water heater makes more sense in our mini-rv applications.
In fact, I believe they make more sense in a real property home application as well. I have never understood how an instant on water heater could be more efficient for anything but quick showers never in a bath tub or soaker bath tub application - and never, ever, ever if you let your house dip below freezing when you are not there.)
boywonder: I have no doubt that you are truly a "boywonder." While I just wonder (about alot of stuff actually...) So, would you please provide one instance of the full word (i.e., "xxx") for your abbreviations in your formulas above? Actually, I see that you have done that, thanks, except for what Mr. Ohm says - what is P = VI?
01-26-2015, 06:22 PM
#29
350 you never heard of pie or a PIE chart? He just used V for E or are you just funnin?
Ohm's Law Defined, Ohm's Law Pie Chart
Ohm's Law defines the relationships between (P) power, (E) voltage, (I) current, and (R) resistance. One ohm is the resistance value through which one volt will maintain a current of one ampere.
( I ) Current is what flows on a wire or conductor like water flowing down a river. Current flows from negative to positive on the surface of a conductor. Current is measured in (A) amperes or amps.
( E ) Voltage is the difference in electrical potential between two points in a circuit. It's the push or pressure behind current flow through a circuit, and is measured in (V) volts.
( R ) Resistance determines how much current will flow through a component. Resistors are used to control voltage and current levels. A very high resistance allows a small amount of current to flow. A very low resistance allows a large amount of current to flow. Resistance is measured in ohms.
( P ) Power is the amount of current times the voltage level at a given point measured in wattage or watts.
I'd better not say how we learned the resistance color code (BBROYGBVGW) but maybe you've been there schoolin wise?
01-26-2015, 07:41 PM
#30
[quote="E350"]reelchef67 and boywonder: To me it comes down to capacity. I will likely drive more than 30 minutes to a camp spot so both units will be adequately heated upon arrival. The storage tank type will have 2.5 gallons of usable hot water while the instant on variety will have 1/3 gallon of usable hot water. So, unless I am missing something, the storage tank type hot water heater makes more sense in our mini-rv applications. "
I agree with you completely however the one that is my van was designed for producing water for beverages(tea coffee etc) ie 190" not for showering etc.. Ypu don't need more than 120 water for that purpose. I would rather have a larger tanked system but no room in my van so this is what I am stuck with. The tanks is 1/3 gallon but once it heats up it keeps producing hot water fairly steadily when mixed with some cold makes enough for a impromptu rubbermaid bin "shower".
for me it is what it is..
