Re: Elecrical Outlet Amperage Max
Dowgars, every year I go to several trouble calls where people plug in space heaters, 110 air conditioners, or other high load items into standard home outlets that eventually fail and burn up. Don’t get me wrong, I’m not saying leaving in the 15A socket won’t work; odds are you’ll probably never have trouble, especially if the breaker is dedicated to the single socket. There are other reasons why people have problems and the socket fails. Some are corrosion, not plugging in the device fully, plugging in more than one item, etc., but I’ve also seen quite a few failures when folks had a single item plugged in that pushes the limit. Almost all of the failed sockets have had devices plugged in that run on a continuous basis.
If you do leave in the 15 amp socket, it might be a good idea to check it. After you’ve ran the AC for several hours on a hot day, check the plug on the AC to see if it’s hot. Slightly warm isn’t a problem but if the prongs are discolored or the plastic housing looks slightly melted, it’s probably time for a new plug and cord on the AC. At that point I’d also replace the socket.
Is the 12.8 amps a continous rating at 120vAC? If that is a startup rating chances are the normal run amperage will be slightly lower, but if that is a measurment while the compressor is engaged, lower line voltage might be an issue. A problem with an RV is that it’s very possible to run into those low service voltages. It’s very common to see voltages at 116 or lower at the pedestal which not only puts a strain on the air conditioner, it also causes a rise in current the device pulls. So at 122vAC you would probably be fine but at 114v? As simple as it is to replace the socket with a heavier version, I wouldn’t think twice about it. JMO for what it’s worth.
I'm not saying anything about the rest of your system. You really need to research that.
