Originally Posted by bassfarm
I just pulled every fuse under the dash and with my house (not starting) battery hooked up, the fan under the bench seat runs continuously. Could unhooking the house battery when stopped/camping have caused my starting battery to drain due to being connected by the isolator?
Thanks for all the help!
If the isolator is working, it should prevent this. It is difficult to offer up advice with out knowing what you actually have installed, your rig is older for one thing, and then also could have modifications from the PO.
I expect that you have a suburban heater, is the heater propane? is it blowing just hot air? Do you have a manual? if not a 2004 (and 2008) version is posted via this link.
http://www.sportsmobileforum.com/for...nuals-116.html
What did the PO do with the wires that went to the thermostat? Was their some kind of switch added?
As other have said find the fuse box for the house side of the camper. There should be a dedicated fuse for the furnace (15 amp). Once you establish a couple of these things, we can probably dig deeper.
to check a isolator , it should look something like this. It could be bad, but it would not cause your
Instructions for testing a isolator,
INSTRUCTIONS FOR TESTING A SURE POWER ISOLATOR WITH OHMMETER*:
1. Remove all wires from the isolator.
2. Using a needle movement ohmmeter RX-1 scale or a digital ohmmeter diode scale, hold the Red* probe on the terminal "A" and with
the Black* probe touch terminal #1 and #2, and the "E" terminal for 3A isolators (group 2), and the "R" terminal for (group 3) isolators.
A good isolator will show a current flow from "A" to #1, #2 and "R", and no current flow to "E".
3. Next, hold the Black* probe on the "A" and with the Red* probe touch terminal #1 and #2 (terminal "E" and "R", if used). A good
isolator will allow no current flow from "A" to #1, #2 or "R" and will show current flow from "E" to "A".
4. Hold one probe on the aluminum heat sink, being sure there is contact by scratching through the protective coating. Then touch
with the other probe, terminals "A", #1, #2 (the "E" terminal for 3A isolators [group 2] , the "R" terminal for group 3 isolators). A
good isolator will show no current flow.
5. Colored terminal indicates "E" post on group 2 isolators and "R" terminal on most group 3 isolators.
*On some import ohmmeters, the red and black probes are reversed for these tests.
**If using a digital ohmmeter, a diode scale MUST be used.
