[QUOTE=alta825;173850]OK, this spring I've been noticing that the fridge seems to be pulling more volts than normal, either that or I never noticed what the volt meter said while it was running the last yr or 2.
Loads are measured by amps. When a load is applied to your battery the current causes the voltage to drop, how much depends on the ampacity of the battery, resistance of the wire and connections, the state of charge and the amount of current. It's normal for your voltage to drop. If your seeing more voltage drop than in the past (with the same load and at the same starting voltage) its possible the reserve capacity of the battery has been reduced. This could be due to a battery getting older and sulfating, a charging system issue, a bad connection, low battery water or other isues. Make sure your battery is fully charged to a resting voltage of something like 12.7v. Then check the voltage drop again and see if it's close to what it has been in the past. If it's much higher, look for bad connections or suspect the battery getting old. Since yours is pretty new, I suspect it's not getting fully charged or your have a high resistance connection. The lower the state of charge, the more the voltage will drop.
