Old 11-07-2013, 06:35 PM   #1
Exterior AC Outlet?
Has anyone found a nice weatherproof exterior AC outlet?
I have the two holes in the side of my van from an old Suburban Propane furnace that I would like to convert to an exterior outlet.
Thanks,
Taylor
taylorvon is offline   Reply With Quote
Old 11-07-2013, 07:05 PM   #2
Re: Exterior AC Outlet?
You should be able to get one at any RV supplier. Check CampingWorld's website. Make sure to have a GFI outlet out there, though.
SMB might sell you one, too.
Old 11-07-2013, 08:44 PM   #3
E350's Avatar
I have one of these and I like it:
http://www.marinco.com/product/30-amp-1 ... less-steel
Edit: I actually have two of these, one mounted on top of the other. One is for 110v AC outlet and the other is for 100v 30 Amp Shorepower inlet.
Old 11-08-2013, 06:24 AM   #4
I guess I should ask for clarification: are you looking for an external "outlet" to allow you to plug in regular 110v/15 amp plugs for appliances and whatnot, or do you want an inlet for 20, 30 or 50 amp shore power?
Old 11-08-2013, 08:26 AM   #5
Thanks for the link threefiddy..
I have a marinco shore power connection as well, but am having trouble sourcing a nice exterior AC outlet.
Old 11-08-2013, 10:01 AM   #6
E350's Avatar
It's the same housing, just the inside is different and that is swapable. Check Marinco.
Old 11-08-2013, 10:19 AM   #7
Ah haa! Now I see. Thanks for the heads up.
Old 11-14-2013, 04:45 PM   #8
Do you think this could be used to install an exterior 12V plug as well?
Northfielder is offline   Reply With Quote
Old 11-14-2013, 08:01 PM   #9
E350's Avatar
Take a while to look through the Marinco website. I bought some 12v plugs and recepticals that are not cigarette lighters because I think we are well past using the cigarette lighter plug and receptacle as a power connection. They had an interior fixture and a weather proof fixture both.
But I haven't installed them yet and I don't have the van or the electrical projects kit at this location.
So, again take a look through the Marinco website.
And maybe CarringB or Chance or some other electrical wizard will chime in here.
Old 11-17-2013, 05:51 AM   #10
Here's what SMB installed on our van: a GFI outlet with an RV waterproof cover, like this: http://www.campingworld.com/shopping/it ... tlet/49739
