Old 01-14-2015, 10:52 AM   #11
shenrie's Avatar
Re: exterior led bulb replacements (brake, runners, & blinke
^^^ perfect timing!! that would be very cool to hear your results! ty and i look forward to your response
also, if you dont mind please post up where you got them and roughly what you spent??
Old 01-15-2015, 04:49 AM   #12
Count me among those interested in an LED swap----'twould be nice if it's just plug-n-play!
Old 01-15-2015, 05:10 AM   #13
Karsten's Avatar
If they' only offer full LED tails for the 92-94 vans with amber turn signals I'd be in too. We need to have rear amber turn signals here. Right now, I have amber LED bulbs in the stock reverse chambers und LED reverse lamps below the rear bumber. I think of converting to 92-94 style rear lights, but rather have those in full LED.
'98 E-250 5.4 2WD Cargo Van
Karsten is offline   Reply With Quote
Old 01-18-2015, 12:35 AM   #14
Can you use Amber/white LED "switchback" bulbs?
http://www.ebay.com/itm/like/1113449...lpid=82&chn=ps
Old 01-18-2015, 04:32 AM   #15
Karsten's Avatar
That's what I'm running in the front (no amber parking lights allowed here) and I used the same in the rear of my RAM before. I hesitated to change the bulb socket in the 250 so far since there are the stock tail lights with amber turn signals avail. Right now I run amber LED bulbs in the stock reverse lights as turn signals.
Old 01-20-2015, 10:07 AM   #16
shenrie's Avatar
stopped by the auto parts store to pick up a replacement bulb and found a set of the led ones for sale. said wth and picked them up. led bulb on right, conventional on left.
cant really say i can see a difference between the two. maybe at night?? will try and get another photo when its dark out.
Old 01-20-2015, 07:30 PM   #17
reelchef67's Avatar
I think the led one looks " fuller".
I just received some in the mail and will put them in tomorrow .
2002 E250 5.4 4R70W 2wd 3.5 inch lift Pleasure-Way Traverse on 16x8 with 265/75/16's
reelchef67 is offline   Reply With Quote
Old 01-20-2015, 09:04 PM   #18
reelchef67's Avatar
Ok I got impatient and put one in , in the darkness...
Seemed brighter until I hit the brakes them normal bulb blew it away. Fail
I will repurpose these ones...later
Old 01-21-2015, 06:11 AM   #19
shenrie's Avatar
the "fuller" look is an illusion from the reflector. if i had taken the pic knelt down, it would look different. as i moved, the hot spots would move in both lights. the bulbs also caused erratic blinking. mine are coming out too, lol. appreciate the input reelchef67
Old 01-21-2015, 07:34 AM   #20
When I swapped LED lamps for the incandescents in my Bronco, I changed out the old thermal based flasher unit for an electronic one. No issues with erratic, rapid flashing. Not sure if the older vans use thermal flashers, but you might want to investigate. Other people install a resistor inline with the flasher circuit. Since LED lamps use a lot less current, many flasher units think the bulb is burned out and that's why you get a very fast flash rate.
Coddiwomple
Rpence
Clyde
ormtnbiker
