Old 10-24-2007, 10:25 AM   #1
External Low-Voltage Shutoff
Am sure there are less costly items than this, although it's not too bad. But, this might be a nice item to put in line with those "nice to haves" so that you don't overdrain. Problem with this is: probably can't set the cut-off voltage. Still, it's got me thinking....
http://www.amazon.com/Koolatron-Battery ... 879&sr=1-1
2006 RB50 6.0 Diesel
SMB 4WD
Amsoil
Old 10-24-2007, 11:15 AM   #2
I'm pretty sure I've seen other similar products. If you can't find something that is less "lets plug stuff in the cigarette lighter" you can probably build something.
and then
everything changed
