Old 01-08-2008, 11:39 AM   #1
Flashers
I discovered the hazard flashers on the SMB I bought last month are not working. When I engage the button, only the right turn signal light in the dash lights up, and it does not blink. None of the outside lights were flashing.
Went outside and noticed the right front yellow running light was not working. Replaced the bulb and no effect on the hazard dash lights (left out, right on but not blinking).
I replaced the little round flasher module. Now the right turn signal light on dash blinks, but the left dash light does not. Also, only the right front turn signal blinks on hazards; none of the others do.
All outside running/turn lights work fine without hazards. All appropriate fuses in the fuse box look fine.
Any idea why I can't get the hazard lights to work in the rear (both sides) and front (left side)?
Thanks,
1995 Dodge 3500 5.9L V8 2wd EB-21 PH
mikestead is offline   Reply With Quote
Old 01-08-2008, 11:49 AM   #2
Sounds like a bad or dirty switch.
