Old 07-06-2012, 10:07 PM   #1
JJSporty's Avatar
Frame Welding and Electrical Components
We encountered a small mishap while traversing the Kaiser Pass Road - 168 in the Sierras - on our way to Thomas A. Edison Lake. This is a marginally paved, single lane road with steep grades, and blind hair-pin turns. I clipped a boulder with my barn door hoop step which ripped off, bent the rocker panel, and punctured the gray water tank. Lesson learned – wished I had read BigVan's & Ford_6L_E350's posts of removing/hinging the hoop steps for this type of terrain and/or taking those blind hair-pins curve wide and having faith that we wouldn’t have a head-on collision.
Our question for the experts: the body shop will need to do some frame welding to repair the rocker panel. Is there a danger to our electronic components from the welding process? If so, what should we do to protect those components? Besides the standard vehicle components, we have two coach batteries, a 2000 watt inverter/charger as well as 12v/110v refrigerator, and standard SMB electrical stuff. Any advice on how to protect the electronics?
Thanks, Janna & Jeff
Jeff and Janna
2014 Brilliant Silver MB Sprinter 3.0L V-6 High-Top 144 WB Modified RB-153S Espar D-5 SC Hydronic 200W Zamp Solar
SOLD 2006 White Ford E250 5.4L V8 4X2 RB-31 Modified, PH Full Length Garageable
JJSporty is offline   Reply With Quote
Old 07-07-2012, 01:04 AM   #2
Ultrasport12's Avatar
Re: Frame Welding and Electrical Components
All they/you have to do is disconnect all the battery grounds at the batteries.
Good luck with your repairs...
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Moby
maptester
Van22
Van22
