Re: Getting wires to the overhead console
I haven't found any 12 ignition wires in the overhead, they do have house power (from the passenger side fuse). You have to remove the plugs on the grab handle and then use a socket to remove the handle, I forget the size at this time. I did have a screw going from the pillar molding into the console , remove the button and take out the screw. There is a lot of room to get wires up through that area. You may also have to loosen the visor to get the wires into the consiole area. if you have rear radio switch installed on your rig, you can tap in that location, in my case the wires are black and blue. I do not remember which wire is witch at the moment, but one side would be the 12V ignition going back to the switch, the other is the switched wire coming back to the radio. If you choose the 12V ignition wire, it will power only when it is on, choosing the other wire will tap into the rear radio house power and you can use as you would the radio.
greg
