Originally Posted by PNWVAN
What are some safe heating options.
Safe heating usually means that combustion intake and exhaust are outside the van.....
For propane there are Suburban, Propex, and a few others
For gasoline/diesel there's Espar....
Webasto is another brand.....there are a few offerings that are both heater and water heater.
The Ceramic and Catalytic portable heaters work well, but keep in mind that they are consuming oxygen from inside the van and exhausting products of combustion into the van.
.....so you have a few things to consider....
The main product of combustion is water so you'll get lots of condensation on the windows
The heater is consuming oxygen from inside the van...most portables have a low oxygen cut-off safety feature.
The heater is exhausting into the van.....usually there is little to none CO produced by these heaters, although there are conditions when they will produce CO.
That being said, most of the portables have CO detectors and shut off when there is an issue and tip-over sensors that also shut the unit off.
Most folks using these portables crack a window or two when using them, and shut them off when sleeping.
I'd also highly recommend installing a hard wired CO detector (or if you are planning on using propane there are combo propane/CO detectors) that is not switched...so it's always on....whether you spend the $$ for a permanently installed unit or a portable.
The way I look at it, my van hobby is not worth dying over....so I wouldn't sleep with a portable heater running....especially without a CO detector.
