What am I missing? This is a 7.3 PSD, under hood battery? The main positive power lead? It's a stock part.
Yes you are correct however Ford is saying it's not the stock terminal and the stock one won't work for me?!?! Here is a thread on Expo Portal forum with the same terminal and issue.
So I just spoke with Sportsmobile and they told me it is a Ford factory part... Ford says it's not haha.. Looks like I may be going the bootleg route unless anyone can shed any light on where to find a direct replacement. I'm dumbfounded.
I had the same thing on mine, I ended up having to cut the battery lead wires out of the block thing they're pressed into and put some ring ends on them. I found a HD terminal post with an offset post for accessory wires. Not pretty but it works.....
