I have a 1991 sports mobile dodge ram van 350 conversion with only 28k miles. There is an alarm going off by the main electrical fuse panel. It is the white box next to the refrigerator. It has a red blinking light when it does go off. This is next to the circuit breaker box and the power converter. I’ve read through the manual and It does not have anything about this alarm.
Any guidance would be helpful!
Thanks,
it is most likely a propane detector, if your rig has propane. Have you checked your battery voltage? many times propane and carbon monoxide detectors go off when the voltage gets low.
greg
Also, if you don't know what it is and it turns out to be a propane detector, even if you get your voltage up to par, it probably needs to be replaced. They expire after a while. (5 yrs I think)
Sent from my SM-G935V using Tapatalk
