Old 07-20-2017, 10:45 AM   #1
help with warning light 1991 sportsmobile
I have a 1991 sports mobile dodge ram van 350 conversion with only 28k miles. There is an alarm going off by the main electrical fuse panel. It is the white box next to the refrigerator. It has a red blinking light when it does go off. This is next to the circuit breaker box and the power converter. Iíve read through the manual and It does not have anything about this alarm.
Any guidance would be helpful!
Thanks,
Gary
Garthwick is offline   Reply With Quote
Old 07-20-2017, 10:48 AM   #2
Need pictures.
Old 07-20-2017, 03:47 PM   #3
it is most likely a propane detector, if your rig has propane. Have you checked your battery voltage? many times propane and carbon monoxide detectors go off when the voltage gets low.
greg
2004 E350 EB V10 E/PH 2WD
Old 07-20-2017, 04:46 PM   #4
Also, if you don't know what it is and it turns out to be a propane detector, even if you get your voltage up to par, it probably needs to be replaced. They expire after a while. (5 yrs I think)
Sent from my SM-G935V using Tapatalk
Tags
alarm, electrical system, sensor
