Originally Posted by wlbaker3
I’d expect a max of 30amps on the output side, would it be the same on the input side of the device as well?Bill
The published specifications don't seem to mention the maximum input current, so as always, I would contact the manufacturer for that information. It's probably not much more that 30A though, as I don't see anything that makes me think they increase current beyond the max output of 30A. What ever size wire you use, if you fuse it properly, there should be no danger of overheating the wire. If your run is very long, using a slightly larger gauge will reduce voltage drop and increase efficiency.
