Re: Honda Generator and Portable Air Conditioners.
Originally Posted by NRL
Originally Posted by dowgars
Will a Honda 2000 run a portable air conditioner? They seem to draw about 8 amps. I'd like someone to comment from personal experience if anyone is out there that's tried this. E.g. New Air 10000E. Thanks, RD
I'm using an Amcor 7500btu with the Honda 2000, no issues with startup or operation.
I've tried 3 other units rated from 8500-1000btu's.. One is a sunpentown, and another Toyotomi portable ac.
The Amcor is currently the winner since it's thin, and doesn't require a lot to get it going with the generator. It has a remote and thermostat..
It ran all summer long last year to keep the cabin cool while docked at home. And worked great when we encountered a extemely hot day in Vegas..
It's still running strong.
The best recommendation I can make when you get an portable ac is to try to make a permanent outlet hole for the heat exhaust, it's night and day keeping it chilled versus trying to use the window adaptor. Another thing I did to is super insulate the windows to keep the heat out and wrap the plastic exhaust hose with a thermo blanket covering to insulate the heat.
Here is a shot of the temps I got with the 7500btu in Vegas: 110 outside 77 inside
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
