Originally Posted by myriadmyriad
If your inverter is set to charge at 100 amps, that might cause it. Mine is set to 25 amps.
Jeff
How do you change that setting? The Tripp-Lite has two charge settingslabled High and Low. The default setting (which mine has always been set at) is Low. The owners manual provides no specifications of loads, charge capacity or charge rates whasoever and the Help Line is even less knowledgable than the ifo provided by the manual.
I have put a load meter on the shore power cable and the highest draw rate I have seen on the Charge Only setting is 4 amps. When the battery is fully charged I see 0.8 amps (charging 3 batteries) and this load fluctuates with ambient temperature. So below 40 deg. the trickle rate is 1.0 to 1.1 amps and above 70 deg. it declines to 0.7 amps. The volt meters on the vehicle and RV batteries show the same effect with the voltage going up as high as 14.9 when below 40 deg and down to 13.2 above 70 deg.
But I reaching a conclusion that my unit is faulty and the charge setting is either too high or there is an internal component that draws too much. Yesterday I could not get the Charge Only setting to work without tripping the 15 amp breaker. It has been working for 6 weeks without problem but tripped yesterday for no reason. After several attempts including the manual reset process, it began to work as previously. Removing and exchanging is a difficult process in these SMB installations because there is so little room to work so I intend to use every means to avoid it including going to a 30 amp breaker.
