So is the black cable connected to the van body or van chassis? The body is sitting on the frame with rubber pucks sandwiched between them......you want the black wire connected to the frame......even if it's connected to the body.
Hey, I follow ya.
(and I've had a good night's sleep too...)
This is getting interesting.
The fat black wire that runs from the house battery terminal is
**definitely** bolted to the floor. In fact, the SMB-installed carpet in this area has a very-deliberately-sliced-open window made to allow the end of said black wire to bolt directly to a shiny/clean area of the floor (it looks like it's the forward edge of the rear (driver-side) fender-well.) And it looks like quite a few other electricals share this same ground point.
Photo of the not-exactly-house-beautiful area shown here:
*** also shown in this pic: Skinny green wire running over along the floor on the right, and out/under the wood paneling (grouped with a bundle of skinny red wires) ---
this is the previously-mentioned "skinny green wire" that also runs from the house battery negative terminal.)
AND SO --- if that big black wire is indeed bolted to the *body of the van*......
then am I correct in now seeing it....that it's likely one of
two possibilities going on here?
THEORY 1:
For this fat black wire to be grounded to the body of the van,
there must also be a similarly-sizable second wire (somewhere) that grounds the body of the van to the frame? (Thus completing the ground circuit?)
**I did look** under the outside of the van (directly under the area where those ground wires bolted down to the floor) but didn't see anything other than the other end of the bolt....so I'm guessing for this possibility to work, I've got to head to the engine bay....)
**OR**
THEORY 2:
The second, small green wire running away (and off:under the carpet somewhere unknown) from the house battery terminal -
is it possible that THIS is the chassis ground instead? (looks a bit skinny to handle that duty IMHO however....)
