Old 05-08-2012, 09:15 PM   #11
Re: House battery charging?
All right, I found one of the problems....
Upon doing some more checking for current draws and such, the bank of lights that I refered to earlier (2 pod lights, pourch light, and the over head 12 volt plug in on the passenger side) Suddenly quit working on me. Multi meter said I had 10.19 volts at the house battery. Yes low, but I should have some sort of power at these lights. It turns out that when I was pulling fuses I found that the fuse block itself seems loose and unabale to maintain its conection. When I push the block together all the lights function as they should. These seem to be a two piece block or maybe buss bar is the better term? Anyways it looks like if I cannot tighten the two pieces I will have to replace it. At least it seems like an easy fix.
Now I just got to track down a proper house battery.
Thanks again for the help.
Tracey
2005 Ford E-350 SMB 4x4
6.0 EB 50 floor plan. sold :(
TraceyAZ is offline   Reply With Quote
Old 05-14-2012, 09:43 AM   #12
Got a fresh new house battery (lifeline) and all is well. Its charging good and all my 12 volt stuff seems nice and happy again!
My checking acount however is mad at me....Lifeline batteries are not cheap!
A big thank you for all your help and phone calls.
TraceyAZ
