Old 04-26-2015, 05:52 AM   #1
ArikB's Avatar
How To Fix Dashboard Lights That Won't Light
Dashboard lights gone.
All fuses at the major box are OK.
Is there another hidden fuse box ?
2005 Quigley E-350SD 6.0L
ArikB is offline   Reply With Quote
Old 04-26-2015, 08:55 AM   #2
Tapatio's Avatar
Re: How To Fix Dashboard Lights That Won't Light
Probably need to dig into the dashboard to figure it out. Here's how.
http://www.justanswer.com/ford/2erma...ghts-work.html
Callsign KK6GIY
Old 04-26-2015, 09:07 AM   #3
Viva's Avatar
When I bought my current, 1999 E-350 rig there were no dash lights (which I didn't notice as I only test drove it on a sunny day). Rotated headlight knob to no avail. Then I checked fuses and all were okay. Then I read the Ford diagnostic procedure and it sounded slightly above my skill level, so I thought about what might be mostly likely to be wrong, and figured I'd "throw that one part at it" before taking it to someone else or learning more about how to diagnose. To my mind, that rotating headlight knob seemed like something that would be most likely to quit functioning (the rotation that dims or brightens the dash lights).
So, I got a new headlight switch and put it in. Bingo, dash lights worked perfectly and have remained that way for over a year and many thousand miles.
Of course that sounds way too smooth, right? Well, it was new to me at the time, and a friend with an E-450 said "Oh, if you disconnect the battery you may then need a radio code, do you have a radio code?" Gah, no, I did not. So I didn't disconnect the battery. And then stupidly let the end of a wrench touch something under the dash by the headlight switch. Which turned out to have caused the power locks to quit working properly (which I then had diagnosed and fixed at a shop while it was in for other work). Of course I later found out that nothing happens to the radio when disconnecting the battery, so that was inaccurate information and I could easily have disconnected it (which I do now before doing work!). But aside from that stupid glitch (and the fact that the headlight knob is a bit "buried" in there), it was an easy fix.
Viva
Old 04-26-2015, 11:47 AM   #4
When I put my Kenwood head unit in, there was a wire that was supposed to go to the circuit that controls the dash lights so the radio would dim up and down with the rotating control knob.
Didn't work. In fact, powering it up made the fuse for the dash lights blow. I disconnected the wire from the Kenwood, replaced the fuse, and all is well.
Old 04-29-2015, 12:17 PM   #5
ArikB's Avatar
Thank you all
I ordered the Headlight Switch MOTORCRAFT SW-6352
Will update
Rex
Tomboy
2008 GMC 3500 SMB
marret
