How to repair broken positive battery cable on 2004 E350 6.0
I was inspected my 2 frame rail mounted batteries and noticed the positive battery cable connector to the battery post is broke.
It's not as simple as installing a new end as this is a spliced flag style batter connection. It connects the first battery positive to rear battery positive.
Has anyone experienced this break? A brand new cable is $660 on Ebay. I have a quote for $200 to repair it.
See attached photo. Ford does some stupid engineering that saves money for them and makes repairs hard for us.
Re: How to repair broken positive battery cable on 2004 E350
My negative terminal was on the verge of doing that on one of my batteries. It was also super corroded
I took the cables off and took it into an electricians shop and had them make me a new one. It was way cheaper.
You can go even cheaper if you are willing to tackle the job yourself.
Buy 1 battery cable terminal, flag style and two matching solder pellets, finish with some high-shrink ratio heavy wall heat shrink. It will costs under $25 if you DIY.
I haven't seen them with a two connections on one side (doesn't mean they don't have them). However, they do make them with mis-matched ends, so going up a size on the double cable end should accommodate both cables, but you might want a helper pushing both cables into the molten solder.
I think I can leave the broken connection in and add a flag connector to the left. It will be easier. Need to wrap the broken terminal.
