Old 05-31-2017, 10:07 AM   #1
inverter equipment ground
Hooked up a 1000w inverter and there is an equipment ground.
Where does this ground get hook to, or is it necessary?
hogasm is offline   Reply With Quote
Old 05-31-2017, 08:23 PM   #2
To the same DC ground that you are using, Your manual should specify a minimum gauge.
Old 05-31-2017, 08:45 PM   #3
The ground wire should be the same size as the cables feeding the inverter.
https://www.bluesea.com/support/arti...ttery_Chargers
Old 06-01-2017, 08:39 AM   #4
1der's Avatar
Is it just an inverter or does it also have shore power transfer switch capability? Might be helpful if you post make and model info.
Any kind of battery monitoring system going in with this??
Old 06-01-2017, 10:05 AM   #5
Ray it is the Zamp 1000w pure sine inverter that Lowes had on sale a few months ago.
Unit does a great job of running the Micro and charging 18v Milwaukee batteries
There was no mention in the instructions of the equipment ground, I did not know if it should be grounded to the 12v or the 120v
Old 06-01-2017, 10:49 AM   #6
It is a safety ground and should go back to you DC Ground connection, Given that ZAMP does not even reference it in their manual, you may want to call them.
In general you go with the same size or one size smaller as the DC to battery run, some vendors will also give let you size it based on the size of your DC fusing.
Esme
Amy V
Betsy
darryldickie
