Inverter fan is stays on at random times. Nothing has been used. Inverter is not hot. Fan is going and going. Checked it 20 min later, still running. Had to turn off manually at switch. When I got it back from the body shop, I noticed the same thing. Did not know there was a switch, so I hooked up to shore power as I needed to charge house battery anyways. That seemed to reset it.
Which inverter do you have (sorry if I missed that somewhere else)? I am getting ready to install a Xantrex ProSine 2.0 and this might be good info to address pre-install.
I have a trace Legend 1.0. I am now expierencing a new issue. The red led is flashing rapidly. In trouble shooting it says it could be a multitude of issues. To hot (nothing on, cool), over charging condition(nothing charging), low battery(checked 13.6), Full battery(maybe). Dont like the full array of issues to be shown as the same code.
